Lifting my engine
I pulled my engine and tranny up through the top with no promblems. You would be better off doing it that way. Good Luck
Ive never actually seen the bottom drop process, I guess since its done fairly easily out the hood I've never tried it.
I think the steering rack is in the way or you would be able to drop it like a honda with subframes and such already on it.
Yes it can be lifted out the top with the trans, you will just have to angle it a bit on it's way up. I even managed to take out my motor, trans, AND transfer case through the top with just a bit of wiggling. I think this is a lot easier than dropping it from the bottom!
Thanks alot guys. I just dropped my tranny last night out the bottom. I'm rebuilding my enggine and tranny at the same time that's y I dropped the tranny first (rebuild place is in Chicago) I wanted to know for when I put them both back in. Isn't there a device you can put on the lifting chain that will allow you to tilt the load?
I've seen some people have that device in their pictures of their builds, but I have no idea what it's called. When I was lowering the engine and trans together in my FWD 1g I had a HELL of a time. I had to let the motor and trans practically sit wedged between the fenders and readjust the chain many of times. I would recommend dropping the motor in first and bolting up the mounts and then pull the transmission up from the bottom, just the opposite of how you dropped it out.
In the time it would take you to remove the tranny, you would have had the engine and tranny out from top.Takes me 45 mins to have them out good luck
Pulled my motor and trans from the top and put it back in the same way. Pretty easy and quick, just takes two people. One to operate the engine hoist and one to watch the engine/trans closely to make sure it doesn't snag any wires or lines and if it does, to maneuver it around said obstacles.
You can buy a load leveler at Autozone. It makes things a lot easier. Motor or tranny+motor through the top and tranny from the bottom seems to be the method of choice.
I would say, you don't really need a load leveler. As long as you have two people( I only had myself :( ) you can tilt while the other person lowers the hoist ( again I did it by myself so i put it on auto drop ;) just loosened the bolt a tiny bit while i jiggled it in). So save that money for gas:thumb:
You don't need a load leveler but I would suggest it. I have used one and I have also pulled one with 2 chains, on bolted to the driverside motor mount and one just wrapped around the tranny, I'm going to go ahead and advise against doing that.
I pulled a motor/trans together last week by myself and dropped a a built one in, It is allot easier with out ABS...my car I riped the abs out it gets in the way Bad going in or coming up an out, gotta tilt everything allot it's not really a big deal if you have someone else around But I did'nt...But anyway You overheated and pulled the Whole Motor...?
your not referring to abs as in brakes are you? but yeah it was a really bad overheat, i had 2 qt of coolant in the whole system...:nono: i had to tow the car back home because it wouldnt stay started. got it there went in and replaced the water pump, timing belt, tensioner, tensioner pulley, balance shaft pulley and belt.... so got that all set with the engine in the car:cry: that wasnt fun. only to start it up and hear two distinct knocks. 1 is a lifter, i ran the car with the valve cover off and could see and here which one it is. and the other i could not determine, i wound up paying mitsubishi to tell me what the knock was. towed it to the dealership only to find out it is a rod knock which is what i suspected. so now im replacing the lifters and putting a new SHORT block in:thumb:
On your new motor, I'd recommend getting oil analysis done for the first few oil changes at least (I get one done each oil change). It will let you know how your engines doing on break in - it also warns you well in advance if something wonky is going on with your motor. It's cheap insurance if you ask me. I use this place:
Blackstone Laboratories
wait it is impossible to run your car with the valve cover off!!! I think you ruined your engine. not the overheat. Rod knock is ussually cause by oil starvation...
Ok my buddy tried doing that once and i laughed my ass off... Oil was everywhere hahaha....
There is a sequence for the break in. I would search for that sequence...
  • Wanted 6 bolt NT water pipe
    • chrisman287
