bosljeff
Okay, vfaq and other posts have installs regarding the lifters, but they aren't all that specific.
I'm installing 16 3rd gen lifters and I need to know specifics/details:
1. Should I do an oil change just before, just after, or both?
2. Should I do an engine flush just before, just after, or both?
3. Can I simply make a mark on the timing belt so I can remove the cams, drop the lifters in, then reinstall cam and belt?
-Would I still have to check/adjust the timing?
-Or should I just take the time, tough it out and leave everything in place and pop the old ones out and wedge the new ones in?
-I remember one time simply taking off the valve cover, and taking just one lifter out and damn if it wasn't a bi*** to put it back in, let alone 16 of em with all that crap in the way.
4. Should I play it safe and install a new valve cover gasket?
Ideas, thoughts, suggestions, tips, step by step, links: all would be appreciated.
Thank you.
Jeff
Thank you.
Jeff
