mikejsmith1985
- 129
- 18
- Dec 15, 2009
Bethel,
Ohio
Feel free to bash, Like the title says I was bored now I am done and still bored so I am posting a pic
Still looks ok but I am going to replace the head soon. When I do I'll make a better one.Looks real good actually I'm about to copy the idea
Looks pretty good, I want to see a pic of it installed
Looks good, will it hold up to the temperature?
Not bad for plexiglass. Heat is your enemy with that though. I would have used sheet metal.
Very creative! I think instead of GS-T, you should put 4G63T. HAHA just a thought!
!!! I was soooooooo close to doing it but my brother talked me out of it perhaps on the next one
Good luck with the carbon fiber one. I'm sure it's gonna look very good.
Thanks Iv'e never done it so I am kinda hesitant to try it but if I do I will definately post some pics
so how did you cut it out without chipping it? for instance did you use a jigsaw or do you have access to a bandsaw?
. GL!OK cool that must have taken a while to cut out. just an idea but when you do make the carbon fiber cover you could maybe make a carbon fiber timing belt cover. i cant tell but i assume you have yours off cause of your strut bar
making a mold would be nice, esp if u wanted to re-produce, but if u made a mold, u would ###### wanna use a vac bag setup to make them. so imo, id use oem. And heat is ## enemy.. i did a CF valve cover, and while it lasted a while, the heat finally ate it.. and i did use a special resin for that one too.. just like anything, hot cold hot cold isnt helping lifetime. GL!
