BogusSVO
- 5,886
- 336
- Jul 1, 2009
Pensacola,
Florida
that sould be able to get you a decent "basic" rebuild,
a decent overhaul kit, rod and main bearings, stock rings, stock time belt kit and gaskets water pump
then add head studs (appox $125) and maybe some BC springs ($100)
some gasket kits come with a mls head gasket (I personaly perfer them) (mls about $100)
now pricing of the machine work can vary from shop to shop, so be carfull there
you can clean your block at home and save a few $$$, get a can of easy off oven cleaner, yellow can, an old tooth brush or small detail brush. the cleaner the better (DIY Block clean $20.00)
then your block can go to the shop
torque plate hone (appox $100) and deck the block, as little as possiable
have the head treated to a 3 angle valve job(appox $125) and surfaced($40.00) with the BC spring and stock retainers
and by the time you get the "odds-n-ends" oil ,flilter ,anti freeze,rtv,and what ever else you need your budget will be about spent I bet
IF the money is there, get the main studs ($140 )and have the block aligned honed ($120)
The prices I quoted are basied off of MY best guess or shop prices from my shop or other local shops to me.
get you a new notebook and make the lists, call and get your prices and keep lots of notes.
Time for you to make some calls, and check ebay for a rebuild kit and such, also ask the supporting venders here at DSM tuners if they can put you a custom rebuild kit together, most shops/stores witll give a little discount with the more you buy from them.
SO if you can get your rebuild kit AND studs AND MLS Gasket all from the same vendor you may save a few dollars and you will save money on shipping
