LD25Delta9
- 694
- 16
- Feb 12, 2008
Ft. Wayne,
Indiana
Hey guys, you all know me fairly well as having half-cocked, hair-brained ideas and I might have another one. I'm dropping a small bit of money and would like to know if I should spend the extra on something else. I was once told in a local forum to see what I can get a stock block to do before I go trying to blow the doors off my car. Kind of crawl before you can walk.
Here's what I'm adding to my list, ALL ON A STOCK BLOCK: 550 PTE injectors, MS2 with Wideband, STM Fuel Tank to Rail Kit, STM Return Kit, OBX(flame away)Fuel Rail, New eBay IC Pipe Kit w/red couplers to get rid of some of the funny multi-colored action going on under my hood, and an AMM Intake Mani that I'll be having my friend port at his machine shop for free...sorry Mike. Along with that port work I'll be having the PS/AC part of my UDP ground and the whole unit balanced. I'm not getting cams cause I'm waiting for the winter to buy some drag grind's for my head build. I'm not trying to play with my timing yet, either, so no cam gears. Slow and steady wins the race, right?
HERE'S THE CRAZY IDEA: I have the money.....should I look into meth to get more from my stock block? I've already researched the HECK out of which system to buy and it sounds like it might be a good idea. I know that IF it MIGHT be feasible, I'll need bigger injectors to run more boost. If I decide not to....for now....I'll stick with the 550's and tune my system for 10lbs DD till NEXT season when the REAL magic hapens.
If no one has ever done this, I'll be happy to be the guinea pig and post all the goodies... I just need advice from those more knowledgable in the subject. I understand the principles and how the whole system works, but I'm just not sure if I'm going to acheive the hoped for results. Anyone and everyone with any expierence in the subject, please chime in. Especially Paul with any knowledge of whether or not the meth kit in question can be used in conjunction with MS.
Here's a link to the meth kit and all it's information. http://alkycontrol.com/They make custom kits using all of the same components, they just try to give car specific resevoirs and more convenient fittings with the kits. They claim to support 2G DSM, but it only pops up with the specs for the EVO8 Kit and no pics.
I've read lots of reviews on this particular company and haven't read a complaint yet. The main reason I like this kit is the progressive controller and for the possible performance gains, $575 dollars is well worth getting a stock block Dyno record for the little guys! ANYHOO....Let me know what you guys think. Thanks for your time!
) to note is that I did all my pulls on 103 to 116 octane. But again still not knock limited by plenty. I actually did over 400whp on 103 octane (my fault). No knock. So then you ask yourself, why go meth? Why not just go high octane (110, 112,116)?
), maybe a whole lot of time with nothing to show for it, maybe a burnt piston, maybe a thrown rod, maybe a hole in your block, maybe a hole in the head etc. etc.
