MaNGiNa24
Supporting Vendor
- 935
- 12
- Oct 3, 2002
Marlborough,
Massachusetts
I just saw this on the bimmer forums so I'll just quote strait from there, I haven't done this personally but I think a lot of the members here could benefit from it. This was all done by a product called "Leathemagic".
It came out great. Let me begin by saying the kit was purchased through Leathermagic and comes with the Dye, Cleaning Prep solution, Latex Golves, Conditioner, small 220 grit sandpaper, areosole type can if you want to spray the dye on but it is very small, wedge type applicator as well as very nicely detailed instructions. Not bad for a little over $40. My seats are Dove Grey so for those with Dove Grey seats, I found their Light Silver Nappa matches a whole lot better then the Dove Gray color they also sell. Their Dove Gray is way to dark.
So let's move on first to the writeup and then follow with some before and after pics. Now let me state that I did not remove the seats, only tilted the back part as far as it would go down.
I highly recommend doing this in a lint free environment in your own garage where your not obstructiing another car or if you live in apartment, do it in your designated spot as the last thing you need is to do it somewhere else and then realize you can't sit in your seat for the next few days while the dye is curing.
Things you will need:
Large garbage bags or newspaper to cover surrounding areas
Additional sheets of both 220 and 1000 grit sandpaper
Woolite for cleaning seats (6 parts Water, 1 part Woolite)
Mr. Clean Magic erasers also for cleaning, it works wonders
Soft or Medium soft toothbrush for hard to reach areas when you clean
Towels for any slippage of material etc..
Spray bottle of clean warm water
Spray Bottle of mild soap with water
Some type of dye applicator, I used those wedge type ones with the handle
Terry Cloth Applicator pad/sponge
Now onto the steps: - I waited till it was a sunny warm day, 90 degrees with o humidity
1. Vacuum, Vacuum, Vacuum. especially in the crevices, use a small firm painting brush in crevices if needed to remove all dirt particles.
2. Clean areas where you are dying the leather with Woolite first the follow up with Mr. Clean magic Eraser and the spray bottle with water and soap mixture. If you want to use some other cleaners, by all means..
3. Wait an hour for leather to dry out.
4. Wearing the latex gloves, apply the Leather prep with the applicator spong on seat, you will notice some of the color fading away, that's a good thing.
5. Wait an hour to dry
6. Start sanding with the 220 grit sandpaper but VERY lightly and make sure to be careful around the seams.
7. Wipe down seat to remove sandpaper residue with a damp cloth. Use the clean water, NOT the one with soap.
8. Wait an hour
9. Time for applying the dye, brush in light coats to avoide streaking and wait at least a half hour to dry, depending on how how it is outside of course. Keep add a few more light coats until you are satisified, waiting for each coat to dry.
10. Wait a few days and then apply some conditioner like Lexol or Leatherique. The kit also comes with condditioner which has a leathery smell but is very small.
In some areas I applied a bit too much dye and they seams are somewhat covered up but hey, it was my first try.
Anyways, I am sure I be missing something here but if it comes to me, i'll edit the post.
Final Result:
Here is the original thread:
http://forums.bimmerforums.com/forum/showthread.php?t=390458&highlight=alcantara
8. Wait an hour
Final Result:
