Cheap & easy dynamat substitute
Status
Not open for further replies.
4geze63
891
3
Nov 18, 2003
edmonton,
If you goto the furnace and ducting erea of your local hardware store you should find a material very similar to dynamat at a 1/10 of the cost.
Most of you prolly know what im talking about but for those who dont it looks like tin foild with a sticky moldable layer underneith approx 1/4" thick. it comes in a roll abit bigger then a toiltepaper roll.
Heatshilding is what it is. For my 1g it worked great, especially on the dash speakers, if you remove your dash speakers you will notice that it isnt sealed under the speaker, basically open to the whole underneight of the dash, same with the rears, I hevent seen how the door speakers look.
So what I did was take the heatshielding and mold it to fit into the speaker well, I lined the inside where the speaker sits and closed it off thus making a little sealed enclouser for my speaker.
I will easily have enough to sound deaden all six speakers for only $12, sofar all Rattles and vibrations are completly gone with better sound imaging:thumb:
If you use anything like dynamat does it improve sound? What I mean is I get poor sound from my door speakers, if I use it will my speakers be louder?
well what dynamat and similar materials do is block the sound from obsorbing into the body of the car, and instead provide a layer for the sound to bouce off and continue in the intended direction.
Not to mention it is a great insulaotor, keeps your car warmer inside in the cold, if you have enough of it that is, it also deadens outside noice from coming in just like the inside speaker noise from going out.
if done properly you shoud notice a higher clarity in your speakers with better overall sound
is it heavy? i know dynamat can easily add up to alot of weight.
thank you.
"great stuff" is a nightmare to work with, so good luck with that.
thank you.
afull sounddeadend car would gain 25 pounds max, same as removing spare tire
Anyone know the name of the dynamat lookalike? I was down at home depot today looking for it but no go, found the sprayfoam but nothing like dynamat. Closest thing was that pink building material and gutter repair rolls. Thanks for the help
It comes in two different sizes ive seen, 2" by 15' or 5" by 15'. YOu will find it in the plumbin section under pipe insulation. Normally you wrap it around pipe
Status
