leaky ps pump
brucerap
Nov 12, 2003
Anyone have an exploded view of the ps pump. I've got a leak at the banjo fitting at the top. From what I've read, there should be 2 o-rings, but mine has only one. Need to get this taken care of before it takes out my alt. BTW, I searched, and the only link to an exploded view was dead.
Taken from the vfaq....
Power Steering pump leak - if your power steering is leaking from the top hose leading into the pump, the dealer sells a kit for 1Gs containing 2 crush washers and 2 O-rings for the top feed line bolt:
JOINT KIT, P/S OIL PUMP FLOW
3/89-6/90 MB553032
6/90-5/94 MB636425
If the rack is leaking, you will need a to disassemble it and find out what seals need replacing, as CAPS only lists a seal rebuild kit for manual racks (MB844738), they do not list a kit for power steering racks (at least not in the CAPS version I have).
Hope this helps! :thumb:
thx for the info. It's not the rack, just the banjo fitting at the top of the pump. Still need to figure out where that second o-ring goes tho....
