2G Leaking head gasket.
Buddy2
128
35
Oct 7, 2013
Helsinki, Europe
I probably have a minor head gasket leak to coolant. There is stream of bubbles after burbing system well. Also tried taking injector plugs off and crank engine. Still some bubbles. Still need try leak down to verify cylinder number. I suspect my block or head surface was not machined enough well for cometic or there is crack in head. My question is if i find head gasket leaking and switch to oem composite with l19 will it hold 10.5:1 cr with fp green e85 around 20-25psi?
Cometic stuff is garbage period, installed their gaskets on customers motorcycles at the customers request for years and then they jumped into the automotive world and they were junk for bikes and they are junk for cars, never even considered a Cometic anything on any car after experiencing their motorcycle gaskets, they are owned by Wiseco piston. A good oem style gasket should do you fine as long as you keep your timing in line.
It will hold that all day as long as timing is not through the roof. Especially when boost kicks in.
Proper install and your tune is key to having your head gasket hold up.
