spadepro22
- 1,206
- 14
- Mar 13, 2008
Seneca,
South Carolina
Well finally got my 20g put on yesterday and Ill I can say is
. You mean to tell me that is thing dam near, no I think actually out spools my small 16g and hits 18psi like lighting WTF . Unfreaking believable. Can't want to crank this bastard up. I didn't even go with a aggressive tune, we actually pulled some timing until I replace my CAS.
Now the bad. I have a exhaust leak right where the 02 bolts to the downpipe and the shop couldn't get to to stop. They said the flange of the 02 could be warped. After a couple of heat cycles do you think I should take it back to seem if it will line up without leaking?
. You mean to tell me that is thing dam near, no I think actually out spools my small 16g and hits 18psi like lighting WTF . Unfreaking believable. Can't want to crank this bastard up. I didn't even go with a aggressive tune, we actually pulled some timing until I replace my CAS.Now the bad. I have a exhaust leak right where the 02 bolts to the downpipe and the shop couldn't get to to stop. They said the flange of the 02 could be warped. After a couple of heat cycles do you think I should take it back to seem if it will line up without leaking?
