Leak!!
96eclipsegsx56
147
Mar 11, 2011
lowellville, Ohio
I am curious what hose this is exactly and where can i get a replacement? as you can see in the pictures there is a pinhole leak in it...it seems to be leaking coolant? any suggestions?
Turbo coolant feed line. Just take the hose off and go to auto zone and get a new piece of the same size. You can actually delete the coolant feed and return lines if you want to, but I kept mine.
Yeah, turbo coolant feed line, replace it with a length of hose same I/D. I that is a stock turbo, do not delete the coolant lines. Stock MHI turbos are oil AND water cooled.
Many people including myself have deleted the water to the turbo with no problems.
Yeah just a turbo coolant feed line. Nothing significant. Just go to somewhere like oreillys or autozone and they should have one. It should be per molded and cut to fit
