JKGMotosports
- 80
- 2
- May 30, 2005
Vancouver,
Hey well I tried doing that boost leak with a homemade tester. I strapped it on the turbo, and used one of those 300 PSI machines that you can hook up in the cigrette lighter. It was pumping and pumping and pumping, I didn't hear any hisses and the psi wouldn't go over 15 psi. What the hell is going on, should I use a manual pumper?? I noticed on the 14b there is a hole for a threaded screw right beside where the J-pipe bolts go, there is no screw there, could that leak out the boost?
