LC1 sumulation issues
Yes it is. I do not like that you can not tell if LM Porgramer has changed the configuration on the lc1.
Also do I need to change the settings for the out put going to the DB guage? AKA the volts to afr.
I drove the car but the afr displayed on the DB seems to jump around alot.
I did have it set up incorectly. But I am still unsure if the narrow band simulation is correct. What are the paramiters when siming narrow band suposed to be?
Ok I am still having issues with this thing. At idel I am reading an afr of 17 on the wideband even cold idel.. But this thing smells like its running rich and have a major missfire at lower rpms (I belive it is fuel related). It shows 0 volts when logged through my open port. But it read around 10 at wot.
I have not logged it in a while but my wide band shows around 16 afr at cruise.
I have just done a free air cailbration with no change.
Also I set it to these paramiters:innovatelc1orlm1install [ECMTuning - wiki]
But when I save it they change:
Analog1 goes to: 1v set at 14 saves at 13.99 0v set to 15.4 saves at 15.39
Analog2 goes to: 0v set at 9 saves at 8.99 5v set to 19 saves at 18.99
Am I using the wrong settings? I have also used LM3.15 and LM3.27 same results.
I finally got a good idel 1000 rpm 24afr at operating temp (I have a bad ICS I do not allways get a good idel).
