Laser Gold Edition Paint Codes
Connnnorg
Jan 31, 2013
Crowley, Texas
Yes ive used the search but there is a discrepancy there. Both the "Deep Green Metallic" and "Everett Green" are both G36 which is the number sitting under my hood on a '93 Laser Gold Edition. It is the two tone with the grey at the bottom. there is a two tone option on the code page but it sits under Eclipse.
Automotive Touch Up Paint from PaintScratch - Order Pro Grade Paint
Yep, G-36 = Deep Green Metallic
Same paint code but Mitsu and Ply had their own names.
Like my Laser: R-33 Ply calls it "Raspberry Red Metallic, while Mitsu calls it "Napa Red Metallic"
I'd use the Mitsu two-tone code: Two Tone Color Combination
Paint Code: G0A
Color Code: G36Everett Green Metallic
Color Code: A16Quartz Gray Metallic
Remember, the Laser came out of the same plant as the Eclipse thus it prob didn't matter which line used the paint booth since the bodies were just bare chassis. It was prob after the paint booth that the painted chassis headed down it's respective line for assembly.
You just got a Laser that got painted for an Eclipse build.
Example: like one time I had an Eclipse that was destined for the 4G63, but got the 4G37 instead, yet the VIN showed the 4G63 install..and this vehicle also got the 'bump' hood.
Things like to happen at the factory at times.
DSM
