Checkers
- 86
- 0
- Sep 5, 2010
Brewster,
New York
On my 99 Eclipse I have 17" wheels, and I've heard that larger wheels can affect the speedometer. Is this true? If so, can I recalibrate the speedometer somehow?
. I'm not sure if it does if you lower it as well.I'm running 19's and I don't really see any problems.
It would actually affect more if you lifted your car. I'm not sure if it does if you lower it as well.
That makes no sence at all!! Shocks/struts have no effect on tire rotations. Ive got 18" wheels and I see about a 3 mph difference from the speedo.
Like it has already been said, wheel size has nothing to do with your speedometer being off. It's the outside tire diameter. This determines how far you'll move with one revolution of the tire. Your car's speedometer is based on a certain distance per revolution. When you change the outside diameter of the tire, you no longer roll that distance. You speedometer will be off by the same percent difference as the difference between your tires' circumference and the stock circumference.
For Jeeps and other vehicles that get lifted for larger tires, they have aftermarket "speedo-healers" that correct the speedometer. This can be as simple as a different speedogear, or as complex as an electronic piggyback unit that converts the signal to the correct output.
And yet the wiseman just explained to us that cars that get lifted get their speedo recalibrated
Where is an actual accurate source to get distance from? On the Autometer speedometers they want you to drive x miles to calibrate, but who really knows if mile markers are lain that accurately. I would think a dyno would be pretty damn accurate.
Test your speedometer accuracy by driving by a radar sign which displays speed, or by the milemarkers on the side of the highway, or with a GPS device which has speed display capabilities, such as a Droid or iPhone, or do all of the above.
I've used the mile marker method, GPS, and those radar speed signs and they all say the same thing: my car reads 105% too fast/far. So I get an extra 1/20th of a mile for every mile. At an indicated 63 mph, I'm actually only doing 60. A tire with circumference 5% larger would fix the error.
He said "lifted for larger tires". The circumference of the tire is the only thing that affects your speedometer reading. Your suspension and/or overall ride height has nothing to do with it at all.And yet the wiseman just explained to us that cars that get lifted get their speedo recalibrated
