2G KYB AGX Shocks/Struts 2G
Nextlevelperf
Feb 18, 2006
Norfolk, Virginia
Since the Dodge Avenger is basically the same as an Eclipse from the seats forward, would a set of KYB AGX struts fit a FWD Eclipse ?
I am thinking the fronts should bolt right in and maybe the rears, but I'm not sure.
There is a VERY clean set on a car in the junkyard here, on an Avenger. First thing I saw. I was quoted $75 for the set, so its a steal!
I saw it has a red rear anti-sway bar too, but I don't think it will work for me.
Anyone have ANY insight as to if any of these parts will fit my 95 GST ?
Thanks!!
Ok I found that the rears are a direct fit, which surprised me. However does anyone know if the fronts will even fit ?
I don't see why not...
Since you tried it out, what harm can it do if you try it out on the front? Just take it easy though, double check all your hardware, and be easy on the test drive afterwards. One who aims at nothing is sure to hit it. (I forgot who said it, but credit is given)
