Knowledge on the 4g37
4g37NonTurbo
Mar 1, 2008
hayward, California
I need facts on the 4g37 sohc 1.8L engine for the eclipse...if it is at all possible for a turbo:confused:
Run a search for 4g37 turbo and you will be a much wiser fellow. Good luck if you decide to try it.
And in this wonderful state you might have problems getting it past the SMOG GODS. Just somthing to consider OMG
One more Q.... will any 2.0 parts fit on the 1.8 or no not at all
you could make a 1.8 awd. that's about it. the trans are probably the only thing that are identical.
I have a t25 turbo i might be taking off soon when get me a 14b turbo and you can slap that on to waken it up LOL
Do some research. The 4g37 and 4g63 come from two different engine families. Accessory wise, most of the things like A/C and powersteering will swap between the two. When it comes to the long block, because they are from two different families, parts will not swap. The blocks, bottom ends, and heads are completely different.
Anything else you'd like to beat to death?
For the 1 millionth time.
awd 1.8 hMmmMm... parts should just bolt right up right..
  • Wanted 6 bolt NT water pipe
    • chrisman287
