Knock sensor wire
Indian
618
Dec 15, 2009
Bishop, California
So I had a little mishap with my black/white wire that leads from the ecu to the knock sensor. Does anyone know what pin the black wire with the white stripe leads to on the ecu so I can rewire it? I see on the ecu pinout that #9 would be the detonation sensor,but I believe that the solid white wire leads to it. Any help is appreciated.
The knock sensor wire begins life as a white wire at pin #9 and ends up a black/white wire at the knock sensor plug. Looking at the wiring diagram it shows that just before the knock sensor plug it joins with the ground for the oxygen sensor and becomes the black/white wire you see. Follow it back from the plug to see exactly where.
Thanks for the reply,the problem is I cant find the black/white stripe wire anywhere as it has sunk deep into the harness. I found the shielding where it ripped off,but no black/white wire.. maybe im misunderstanding?
