loser3000
- 0
- Oct 1, 2004
Boise,
Idaho
I've read through some of the common problems for causing knock, yet am unable to fix my problem. I have been getting 43 counts of knock and -2 degrees of timing. I replaced knock sensor, fuel filter, injectors, bov, plugs, revised lifters.. checked every hose for boost leak, plugged the egr valve, and none of that had solved the knock problem.
I have changed out the ECU's, along with the Maf and neither of those made any difference.
I ordered in some of the revised 3g lifters, installed them. Problem is still there. Could it still read knock because they're trying to settle in?
It's timed correctly, 5 degree base timing. Still reading knock and pulling timing.
It's almost as if it's not giving fuel, as though a lean knock, or the fuel pump's not working. There's a little bit of voltage lag in the O2 sensor. I'm still getting .95-.96 volts wot and no knock.
Knock occurs between 2500-3000rpm.
My current setup consists of:
EvoIII turbo, 550 injectors, Gm maft, STi fuel pump, stock smic and stock boost
Anyone have any suggestions?
