Keydiver chips
WHITE GST
77
Sep 24, 2004
BRONSON, Michigan
Does any body know if the they can be used on an automatic or they are just for a M/T?
I did search but i could not find the answer!!
THANKS.
You can have them use any OE code base on the EPROMs... Like mine, I had an EA02 code base (for CA, AT, AWD)... I would recommend having them use whatever code base that came in your particular ECU, regardless of what drivetrain the car has.
OK, I just wanted to make sure before i get my ordered, i'll have to get the ecu and the chip, i still don't make up my mind on what size of injectors to get, i think i'm going with the 650's.
Thanks for your help.
RAM.
RAM.
If you go with 650's, let me know I have two "Stage 3" Keydriver chips for 650's that were in my AUTO before I got DSMlink.. I will be happy to let them go for the right price.
Brad
Brad
Sounds good we'll talk about it when i get the injectors, I need to find some 650's and a eprom ecu for cheap some where.
THANKS.
