Kaaz rear lsd intall?????
mattmullin
94
15
Aug 20, 2009
North bay, ON, Canada
Hi!
I have a kaaz rear lsd i want to install this weekend..
I have a few questions. What are the clearences and spacing? also should i get new carrier bearings?
Thank!
Matt
P.s i also have a cusco center and a quaife front. any heads up?
If your redoing the any axle its highly recommended to put new bearings in. Just take your time with it triple check everything and you wil be fine. Make sure that all parts are lubricated properly before you close it back up.
Hi!
Thank!
Matt
keep your used bearings your going to need them for testing the back and side to side lash a press and a dial indicator
I'll be droppin the rear diff housing this weekend, rite after i finish my front end and relocate my fuel cell.
Hey, how do you post pics? you guys might like this!? i tubed framed the whole front end, rite in front of the strut towers. And i wanna mount the rad in the rear as well. buildin it for tarmac rally and time attack...
I finally finished the install, i had to frakenstien some axles together using evo 9 rear axle stubs. works perfect! and this is on a 1st gen.
you know i had a discussion about those kaaz rear lsd on this site just about a couple of days ago. i ask if anybody have experience with these lsd and had a few responses. i have a lot of good responses with these lsd but only thing is they are expensive. i am now looking into getting stock evo stock rear lsd and putting in the 2g because its going to be a little cheaper. how much did you spend on that kaaz lsd, did you got it used?
The easiest way to upload pics is to upload them to somewhere like photobucket.com and then use the
