just no spark no one can figure it out
na2geclipse
Mar 2, 2009
Rialto, California
i have a 97 eclipse rs 5 speed had my head rebuilt and it ran good for 30 miles i got off the off ramp and car shut off when slowing down i changed the ecu crank and cam sensor asd relay coil pack did my timing 4 times and still doesnt start it has fuel but doesnt spark thats my only problem if u can help or know someone that could help it would be greatly appreciated thanks...
Have you actually pulled all the plugs one at a time hooked up and have someone crank to see if you dont have spark visually?
Remember to start from the front and work your way back. Start with plugs, then wires, then coil, transistor, CAS and last but least the ECU.
ya i stuck a screw driver in each one one at a time an no spark it just cranks and i have good compression...
just checked again and no spark but got only one after cranking for about 20 sec and it backfired super loud..
