Just installed AFC, Car wont's start! Help!
V8HAHA
257
Jul 5, 2004
Seattle, Washington
Ok, hooked everything up according to vfaq, plugged the ECU in real fast before we snuggled everything away, ran great, afc worked. the we snuggle the ecu back in, try to start the car again to be safe, AND IT WONT START! What could this be? I checked the connections over and over. Give me suggestions.
OK problem fixed. It was the MPI fuse.
Jott- Is your car starting? if so, then the AFC is grounded wrong, or is powered wrong... or blown (never heard that happening before). Make sure you put the 2 grounds in the right place. and power it right.
ya check this out.. i took and hooked it up to a biddies car and the unit worked fine.. so i rechecked 3 times all the wireing was right. so then i got annoued and used the ignition wire from the stero harness.. still nothing. then i swapped the ground. STILL nothing. and the brown wire is the one most twords the ecu.. just like the directions said.. im going to have a electronics buddy hopefully check it out soon.
