just installed walbro 255, and the car wont start!!!
dsm-power36
154
Feb 22, 2005
waterford, Wisconsin
Okay So I Just Installed The Pump Twice! Its A Walbro 255, I Used The Directions Off Vfaq And When I Try To Start The Car The Pump Cranks, And The Car Turns Over But It Will Not Start! Do I Need A Better Fuel Pressure Regulator? Help Please
Thnx Nick
i have the stock fuel pressure regulator, 550s, front mount, safc-2, stock turbo, full exaust etc...
Thnx Nick
You might want to unplug the fuel line at the engine bay, have someone check to make sure the pump is actually pumping gas into the injector rail. That way you can tell if it is the fuel pump as the problem, the best person for fuel problem type answers is femmeDSM. She seems to have the best answers when it comes to fuel pump info so PM or message her.
i fixed it after the 3rd time installing it i just needed to put a spacer between the o-ring so no fuel would pass by it thnx nick
