Just installed 1g XS fmic.
90 GSX
322
Jun 24, 2004
Fremont, California
Opinions of kit:
The intercooler itself is very impressive. I don't know what grade of metal it is or how much it affects heat transfer, but I can confidently say the the core looks very well designed based on other cores I have inspected. It is beefy and heavy.
I didn't use a magnet on the piping but a ferrari tech and an engineer both told it was steel, which is my belief as well since it was actually giving a 7" chop saw some resistance (you'll hear about cutting below). However, I went to an exhaust shop to have the ends of the pipes beaded and the blowoff valve flange (steel) welded on. They told me it was aluminum. I do know one thing for sure, the small tube that the blowoff valve mounts to is steel, so order a steel flange, that's all that matters in terms of metal. Whatever it may be, they are mandrel bent 2.5" polished pipes. They may be a little thin but they are suffificently strong for intercooler piping. The turbo outlet pipe looks to be 2" in diameter. It's also a mandrel bent pipe welded onto the flange. The pipe on mine was not completely flush with the flange but the weld was good and I doubt it will affect anything. I guess those are one of the things that make up for the price difference, although paying 5x as much as I paid for this setup (205 shipped) for an sbr or something like that is not worth it in my mind. I have nothing against sbr or any other well known dsm vendors, in fact I have bought many things from them in the past.
The couplers are not silicone but they are plied and seem to be of decent quality. I have no doubt that they will get the job done. They look identical to the couplers that came with my Vortech supercharger that's on my trans-am if that means anything to you.
The clamps are t bolt clamps with nylock nuts. They appear to be sturdy enough. I tighted them with an extended craftsman ratchet and a 10mm deep socket and they got pretty damn tight. I don't know what else to say about clamps but they work.
Opinion of fitment:
To mount the intercooler, they supply some aluminum brackets that have corresponding bolt holes on the bottom of the core. To use them, you have to relocate the power steering cooler or loop it at the reservoir and remove it completely to be able to push the IC back far enough for the brackets to extend under the body so you can screw it in. Instead of doing all that, I went to orchard (hardware store) and bought a strip of steel, I don't remember the gauge but it was about 2" wide similar to the brackets the IC came with. I cut new brackets that were about 1" longer and drilled new holes and it worked perfectly, and I didn't have to remove or relocate anything. On the top mounting bracket, I bent a strip of steel into an L shape and used the perfectly placed bolt hole that mitsu gave use running on the vertical beam that supports the hood latch. I attached a bolt there and another on top of the IC so the steel kind of makes an L to wrap around the top of the IC. The only thing I had to remove was the little bracket on the hood latch that the mitsu center headlight piece clips into (there are 2 other clips, I didn't have mine in the first place anyway haha) and everything fell into place perfectly. The core is so secure that it's practicaly my new inner bumper, which I will need since the stock one won't fit.
You can not use the fog lights or the inner bumper with this kit.
The pipes went in fairly easily although it took some modification. First of all, the UICP is slightly too big to fit through the stock holes, so I just said to hell with it and moved the wiring harness out of the way and cut that whole section of metal out from the wheel well with that 7" chop saw. It was pretty easy actually. I ran the LICP and the UICP through that cut out section, although I don't know if that's how the piping was meant to be ran. Can somebody else with the kit verify that both pipes go through the body in that location. Anyways... only 1 pipe required shortening - the one coming directly off the cold side of the IC. I bought a 90* rubber coupler from home depot and connected the two pipes. It fit together better than I could have hoped for. The rest of the piping went in easily. If you can't get the ends beaded, I suggest you do what I did because it's holding very well at 16 psi. I took an adjustable crescent wrench and flared the ends of the pipes. Working good so far...
The bumper skin had to be trimmed in a few places to fit the IC but it was nothing major at all. Not even worth describing to anybody who is going to install an fmic in their driveway.
Opinion of performance:
I went from a stock IC and piping and all the mods in my profile to this fmic. The difference is incredible. I used to have problems with knock. The stock IC heatsoaked as soon as I put the key in the ignition. Somtimes after a couple pulls, I'll get 7-10 counts in second then shift to third and get 15-20 counts of knock!!!! Now, knock has all but disappeared. Occasionally I get a small spike to 4 or 6 counts but it returns to zero but that may be related to other things... The car feels so powerful compared to before, I mean it's finally getting to the point where I'm satisfied with the acceleration. On my logger I'm getting full timing out of the car, something I have never seen or felt yet, it's amazing.
I noticed absolutely no difference in spool up. In fact, it may spool up a little bit faster than before. Also, the blowoff valve sounds nice now. Much more intimidating if that matters to anybody out there in dsm land.
The IC inlet piping is always hot to the touch, but the outlet stayed ICE COLD after about 12-15 full throttle blasts using first, second, third, and sometimes fourth gear over the course of about 20 minutes. I had fun to say the least. Running my hand along the bottom of the IC I can distincly identify the point at which the temperature changes. After all those runs, the last 1/3 to 1/2 of the intercooler was still ice cold to the touch. I know that's not concrete scientific data obtained in the proper manner, but my ass dyno is giving me a thumbs up.
Final words:
I have a multimeter which also has a temperature probe. If anybody would like suggest an experiment I'm open to any suggestions.
All in all, I don't think you can go wrong with this IC for the price. Even after 1 year, if jean grey came along and disintegrated my core and piping with her telekinetic power, I'd buy 4 more entire setups before I got the price of most of the fmic out there. I mean honestly though, if some company out there can ship me an entire fmic setup of decent quality for 200 bucks shipped, these other guys must be doing something wrong. Yes I'm sure they rely on volume to make money and yes I'm sure it's made in China, and yes I know that some of the finer details are missing, but I refuse to be bamboosled into paying 5x the price for some trivial details and an instruction booklet. R&D ain't that expensive anyway, especially when many of the other kits out there require a similar amount of modification.
I took the leap and bought the xs power kit. It turned out really well and I'm very happy with it. I can scrutunizingly give the kit and A-. Read this, form your own opinions, I hope it helped. Now it's 3 AM and I am getting up in less than 5 hours.
are there any pics of the install or finished version of the xs power fmic... not to many people on here have taken pics of there installs.. im also looking into buying one because i just found a bunch of corrosion holes in my smic... ive also heard nothing but great things about these kits... Great write up!!! :thumb:
Very nice write up. I just purchased this kit and have not installed it yet. I did take a magnet to the core and it did not stick so im pretty sure that the core is alluminum. Also the magnet on the piping sticks everywhere except the last 5-6 inch's of the piping, which I found wierd. The BOV flange was magnetic also.
Anyways you may have routed the piping a little wrong from what I read. Here is how it should look.
http://www.dsmtuners.com/forums/showthread.php?t=212244&highlight=xs+power
I'm having a Horrible problem installing this kit on my car. I am really getting frustrated and thinking of spending money on a expensive intercooler like SBR or extremeintercoolers. I thought this kit was going to be an easy install but it turned out to be kinda a nightmare for me. Right now I currently have the intercooler mounted and now I'm trying to get the piping to fit; which really sucks! It's a MAJOR PITA to get the piping done on this intercooler with the pipes they send in the kit! I really need help and I'm getting tired.
I don't want to bite the bullet for a new kit because I'm already out $200 for this one. I'm really having a problem connecting the long pipe to the turbo outlet pipe; it's almost at an impossible angle. I don't know if I need to push the intercooler all the way back to the oil cooler or get longer couplers and try to get it together. I have the intercooler mounted barely touching the AC line that is coming from the condenser in front of the radiator; is this the right way? I hope someone can help me with this kit because I've tried and tried :mad: :mad: :mad:.
Did you look at the pics on that link I posted. It should look about like that. Also if you buy a name brand intercooler you still need to install it and believe me its just as much as a pain and even harder on the short route kits.
Well, Jayrolla have you installed this kit yet? Man if you did I can use some help. I have looked at that link that you gave me and it does not help. His car is different from the 1990 TSI AWD as I don't have that piece of sheet metal where he puts the bolt into the top of the intercooler; I had to fabricate my own. I have the flip up lights and he has the fixed lights. I have no problems mounting the intercooler, it's just the piping is to long and to short in some places. I am really happy for those who have installed this kit successfully, it's just I need to get it that way :) I see 90GSX has installed his pipes differently as he has said; show some pics for us to see. I can use all the help I can get. :talon:
I love the core but really really want a SBR style short route with blow through for my new 1g. If there a difference between this core and the other 60 dollar cores you see on ebay? It's an all drag car with no comforts so space is plentiful. Otherwise nice write-up and look forward to using my first ebay part. This new 1g is going to be almost all ebay except turbo and fuel.
I also dont have that support, but im going to try and bolt one up from a junk yard. If the piping is too long then cut it. Make a new thread and post a pic of where the problem is so maybe we can help.
just orderd the kit today... 205$ shipped to my door... when i recieve it ill let you guys know how it looks and how the install goes but i dont think ill be able to snap any pics cause i dont have a digi camera avalible.. ill do the best i can... Anyone else out there with some pictures of there installs or even the kit when it was shipped to them ??? :rocks:
Well im back and still pimpin the ssac 1g fmic ive blown off the couplers twice. when i first put it all together some of the pipes were a little hard to do but i just pulled and twisted to get them to fit thats why they blew off. I just took off all the couplers one by one and tightened them back down and i found the second time around its so much easier to wiggle the pipes into place. also the tbolt clamps arnt the best, they hold but i broke 2 of them and i went and got some napa couplers with bent bolts, the straight ones that come with the kit can be broken. But still lovin the kit
