Just got the sbr g57. Now what?
DSMark
189
8
Sep 3, 2005
Glendale Heights, Illinois
Hey guys i just got the sbr g57 turbo and i was wondering, what else do I need for the install? It bolts up to the stock manifold and besides new gaskets what else would i need? I'm pretty sure its oil cooled only so is the oil feed and drain lines all i need? I bought the sbr g series oil feed line, but i don't know where to get the drain line since slowboy doesn't have it listed. Are they the same line? Any help would be appreciated, thanks guys.
If it is just oil cooled, you will have to block off the lines for the coolant or re-route them back into each other. I don't believe a stock drain tube with work so you will probably need another one. I know they offer it in SS with a 45 or 90 degree fitting to connect from your turbo to the pan.
As for the feed line, either hook it into the stock location (at the head) or put it into the oil filter housing and block off the head feed. :thumb:
