Just got my Shep trans and wont go into gear :(
Initial DSM
903
Jan 30, 2003
97 Eclipse gsx, New York
Hey guys i just got my trans back from Shep its pretty much a stage 3-4 with steel forks and all the bells and whistle's ...After i installed the tranny I went to go move the car and it won't go into any gear ...My clutch pedal feels fine ..All i did while the trans was getting worked on was replaced the clutch disk with a sprung act 6 puck cause my old act street disk was getting low ..I dont think its the tranny car wont go into any gear.. While it"s running if i shut the car off and start the car in gear it makes like a scrapping sound...when the car is running and i push the clutch pedal down or if i release it seem the same ..it makes no differance with the clutch pedal in or out ..I am stuck on what to do..i also tried putting a longer salve rod and still nothing please let me know what you think ..Thanks Frank
When the car is turned off can you shift it into gear? Did you properly bleed the clutch? Where your clutch fork sticks out of the bell housing is it in the middle of the opening? closer to the passenger side? Or closer to the drivers side?
Hey brothers i just got done..it was my clutch adjustment all along..i drop the tranny down for no reason i call act while my trany was already dropped and he told me its an adjustment the pressure plate was hitting the springs on the clutch disc..i had to back out the rod under the dash unreal well poeple learn by there mistakes i guess ..Thanks again
Ps>> .. i installed an act sprung 6 puck cause act told me they will handle 513 foot pounds of torque with a 2600 pressure plate and a street disk with a 2600 pressure plate will handle 400
