gieri002
- 786
- 1
- Feb 25, 2008
Lake Minnetonka,
Minnesota
I just finished my head gasket install, I started the car to make sure all was OK since I replaced the water pump, timing belt, and just about everything else while I was in there. Well the car started right up and seems to run good
, BUT it vibrates really bad, the vibrations get worse the higher the rpm goes. I still have my jack on the oil pan and the drivers side motor mount is not put back on yet since I don't want to put everything back together and take it back apart when something doesn't work out.
Well could this be the problem, or is something up with my balance shaft or something, I never touched the balance shaft belt because it was already brand new though. WTF
, BUT it vibrates really bad, the vibrations get worse the higher the rpm goes. I still have my jack on the oil pan and the drivers side motor mount is not put back on yet since I don't want to put everything back together and take it back apart when something doesn't work out. Well could this be the problem, or is something up with my balance shaft or something, I never touched the balance shaft belt because it was already brand new though. WTF
well good job glad it worked out, ive done it 2x like that not thinking
