just bought my 92 eagle talon n/t need suggestions
i have a stroker setup if you wanna go crazy. everything basically avalible for the turbo is availible for the non-turbo except turbos.
you can do cams, stroke that motor, head work, valves, spring retainers, everything you can imagine. it gets expensive and with n/a you dont need as hi a fuel and all like a turbo motor. you will not generate as much power either.
id go bolt on mods first. go with pulleys, intake, header, hi-folw cat, and go from there. good luck
It really depends on how much money you feel like spending. Intake, header and cat back is a good way to go....but for the non turbo its great but theres still not enough power....if u wanna go turbo on ur 4g63 then prostreetonline.com has a TSI turbo kit(not the tsi talon) for like 1700 dollars which adds about 6-7lbs of boost to ur engine creating around 30% increase in power, which would be about 175 crankshaft power, if u decide to do this then u should get lower compression pistons or forged 9:1 compression pistons to handle the boost and a fuel system upgrade such as injectors, fuel pump and regulator to keep from runnin lean...this is the path i am going....good luck with ur car...lata
:dsm:
