just a boost leak or something more serious??
lazer103babe
Aug 10, 2006
Milwaukee, Wisconsin
Not too long ago I got myself a 2g gsx. It runs like a champ, especially considering the fact it has 200,000+ miles on it. Well it's been sitting in the garage for awhile and I finally took it for a spin yesturday, and it just didn't feel right...
I drove it for a good 3 hours.
For the first 2 and a half hours, the turbo was giving me crap.
It would take forever to spool up for starters and would take forever for it to reach boost. It also didn't have the same pull to it, nor the same sound. Normally it has a whistle to it, instead it sounded like it was just sucking in air. I think it might just be a boost leak, but it's been forever since i've been around cars, so I'm not fully sure..
What was the most confusing about it all though was that after a good 2 and half hours of driving, the turbo finally spooled up the way it used to and had no drag to it, but the sucking sound was still there..
I'm confused:confused:
Any ideas?
Sounds like a boost leak. I had similar symptoms last summer, and it ended up being the hose from the wastegate actuator to the BCS.. The hose was old, hard and cracked. Made a world of difference!
Do you have the airbox hacked? My turbo has always made a sucking air sound ever since I opened up the airbox, and then even more so when I did the blow through setup. Double check that the turbo snorkel is attached to the airbox and turbo snug. It shouldn't really go anywhere, but you never know!
  • Wanted 6 bolt NT water pipe
    • chrisman287
