Joe P. IL MBC
This is a review of the new Joe P. IL MBC, which I have been running for the past 3 weeks. First off this is the new inline design, and is very compact with a body length of just under 2"s, & comes in either silver or black, which is great for a sleeper. Its a very simple design, two machined ends, an oring to seal the bodys together & hold your adjustment, then the typical ball & spring. Install is very simple, cut your pressure source to wg actuator hose & install the mbc with the shorter half of the body as the inlet, longer as the outlet. If you are looking at either end clockwise is to increase boost, counter clockwise to decrease. So far this product works great, once you have it adjusted it holds the setting and doesn't come lose and boost is nice and stable. Must say Joe P. was great to deal with and this would be another great product from them.
I have had mine for over a year now, great product!
Same here. Boost set at 15psi, only spikes to 16psi. The only criticism I have is that when you adjust the boost, the vaccuum lines twist which is not that bad of a criticism. But I also have the stock line clamps from the BCS on the ends of the vaccuum lines to help seal things better.
