1G Jmfab o2 housing problem
SasaniFab
2,432
788
Dec 1, 2013
Mexico, Connecticut
Ok so I purchased a jmfab o2 housing from Extremepsi and when I went to install everything it doesn't fit. The Tial Mvr will bolt on to the housing but it won't with the valve seat in the wastegate. Am I missing something here or do I need to send it back.
Yah I've tried that.....I can't even tighten the clamps far enough to put the bolts through
I was thinking about heating it but I shouldn't have to modify something that cost almost 400 dollars. Like I said it lines up perfectly without the valve seat inside the wastegate. I'm assuming this seat is essential.
That's with no spring in the wastegate, just took it out of the box and tryed to fit up up
Ive had to use a channel lock plier to squeeze my v band clamp down close enough to get the bolt through. Maybe that will cause the fire ring to compress and line everything up.
The Valve seat sticks out a few mm, the flange on the manifold has a slot also
I have a JM Fab setup as well, no issues with mine. I have the 44mm MVR. Can you post a couple of pix?
Like I said , it's a perfect fit without the valve seat it, it won't go in for the life of me with it in
I'm not going to fight with it anymore, I spent to much money at this point
Can I ask, were you able to seat the wastegate without a fight?
More or less. I have 4 springs in mine (22 psi base pressure). So it took a little pressure to fully seat the 2 mating surfaces. The clamp went on with no problems.
Ignore the little extended piece, I had that added to clear the water fittings. The setup fit in my 1g with no changes. I just modified it slightly to fit my needs..
I'm going to call extreme in the am. That doesn't look like the recirculated housing?
I'm waiting on a fp black so I don't need it at this point but just a little frustrating
Fits like a glove after a lil love with the pliers . So very sexy
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
