JM FAB Intake Manifold
Oh and if anyones wondering, those are 2g plug wires. It makes the coil pack relocation look much cleaner IMO, rather than the 1g wires that stick up on the coil ends, where mine make a 90*.
Ah yes, I can see it now. Hard to see what was what with all the rubber lines down there. LOL
Man you must have bent the little nipple quite a bit then. I'll have to look into that.
Or i can always add in a 90 degree nipple fitting in there, and just make it two hoses. Hmm.
Here is how I routed my wires with the relocated coil pack. I still have to mount the PTM (It's just hanging at the moment).
Fast Idle Air Valve it why theres coolant lines going to the throttle body.It helps the warm up in cold weather.Hey I dont want to change the subject but if anybody has a picture of a 2g with the JM Fab intake manifold I would like to see em all the pics are always of first gens.
Then do what I did.
Thats perfect Dan. I was actually going to locate mine off the bolt just above the one you did, but I like the one you did because it sits it lower and not as noticeable.
On a side note, what gasket did you use for the intake manifold ?
