jm fab heatshield questions.. O2 sensor wires??
coryf1233
246
Nov 6, 2007
hanover, Pennsylvania
I recently put on the jm fab heat shield. well now the insulator for the o2 sensor wires is melting due to not having the tabs to suspend the wire above the manifold like the stock heat shield does, my question is, what do all you guys with the heatshield do to prevent this
Zip tie it where you can, ive rewired my car so its longer to fit anywhere, it will come in handy when i get my fp manifold.
I used some cable clamps on the right most and left most valve cover bolts to hold the wire since I'm not running a heat shield. Any hardware store should have em. They look like this.
Bryan
