JDM tranny
rogergoochman
86
Jun 24, 2003
toledo, Ohio
I have a 91 TSI AWD and i found a guy with a JDM VR4 tranny with low miles and i was wondering if it would bolt up to the US 4G63? thanks zach
Does it come with the transfer case? The transmission will bolt up with no problems, but your current driveshaft may not be the right spline for the tcase. Is the transmission switchable from 2WD to 4WD? If you're not sure, you can ask him or there are stickers on the tcase and transmission. I had a switchable one, and I loved it. It was convenient for taking it to a 2WD dyno or just taking it to the track to compare differences between 2WD and AWD.
I believe so, but I could be wrong. Your driveshaft may have a different number of splines than the JDM transfer case.
Maybe someone else can chime in?
Most JDM trannies don't have the right final drive gear ratio. What are the #'s stamped on it? :dsm:
I bought the same " JDM" GVR4 motor complete with trans and transfer case (ebay purchase). Found out it was a 1990 (6 bolt, 22 spline transfer case, and external oil cooler plumbing, etc....) Pain in the rear to get the motor in but drivetrain wise - it bolted right up to my 94 TSi AWD's original driveshaft.
