Jdm Swap
killab443
602
3
Nov 24, 2003
Howell, New Jersey
What is the cheapest place to get a jdm swap.No trans and cut harness, with turbo? Anyone have some links?
The JDM will run you $1500+ including shipping. Mine cost me $1475 from Rising Sun Engines for just a long block with the timing belt changed.
You might want to check the head's surface to see if it's flat.
I picked up a JDM with a 16g and yellow top injectors locally for $1230 out the door with a 6 month warranty. No tranny etc. I would call around locally and get some quotes. I found the place that I used in the back of an Autotrader. :thumb:
Wow, all I can say is that's a great price with some great goodies to go along with it. I wish I would have received a turbo with mine, so I could have had a chance to get the EVO 16g turbo :(.
No I no whats wrong with my engine, ive done everthing in my power to try and make it work and its definitly the block ive tryed 3 heads, 3 gaskets(all different), arp headbolts and stock ones too, no matter when it still blows
honestly you're doing exactly what i did (apart from the blowing head gaskets :p)
I recently purchased a jdm engine from osakajdmmotors.com and unknowingly got the yellow top injectors and the 16g and tranny for 1750 shipped. I wouldnt however recommend they had suck ass customer service and the engine arrived with a messed up head gasket and the brown goo below coming out of the block drain where coolant should be coming out.
another you need to be forewarned of - I looked around for quite a while trying to find out what it takes to install a jdm engine in the usdm eclipse and i never found a good answer.
You need to realize this is NOT a bolt in affair. Simply put, there is a lot of shit you will have to swap over - basically anything that has an electrical plug and practically anything external.
I didn't find this out until we got the engine of course, so it made swapping it a pain in the ass. It is almost done with the 16g turbo on but i put the usdm injectors on because this is a bone stock gsx with no AFC or anything.
If i could do it again? I would say get a used usdm engine for say 600 off ebay (yes i have seem them go this low) and then use the rest of that cash on go fast parts.
This is just my personal experience with jdm engines, your's may be different, but if you have any questions, let me know :D
andre
