JDM cyclone questions
2gtalontawdtsi
May 19, 2009
zanesville, Ohio
ok i purchased a jdm cyclone motor, i just used the short block, now i bought another dsm and im making a auto x car. Im wanting to put the cyclone intake manifold on my new 1g awd car. i have the cyclone intake manifold, and i have a cyclone ecu (i think) the number on the front is (MD322364) and the number under that is (E2T38391) and the four digit number under that is (5121) and theres a capital (E) beside the four digit number. I just want to make sure this is a cyclone ecu, and does the (E) mean its a eprom ecu
My second question is i have the complete intake manifold, and ecu. is this all i need to make this cyclone intake manifold fully functional.
Is the actuator for the 2nd fuel rail vacuum or electrical? If its vacuum I don't think you'll have a problem. But if it's electrical you'll need to run some wires from the ECU to the servo I believe. Not 100% sure though.
Does the intake still have the original dark green vacuum actuator on the side? You also need to have the white canister which is a check valve to the system because the actuator is not supposed to see boost. There is a dodge check valve that you can use as well because the white canister is hard to find.
My experience was that I preferred actuating it with a modded wastegate actuator over rpm/ecu activation.
When set up properly, you'll love it!
Not really sure how you're going to use the jdm ecu as i believe its obd1 and your car is obd2. Did you try matching the connectors up with the ecu?
