Is this idle surge, and if it isn't then what is it called?
4gfun
Supporting VIP
2,009
56
Dec 10, 2007
Ask Me, Virginia
I have read alot on how to get rid of the idle surge. Basically, I received my car with the lower honeycomb and silencer removed on the MAS.
The car idles normally when I start it, but after about 3 minutes of warming up, the idle goes back and forth between 800 rpm and 2500 rpm.
I just want to make sure that this is clearly the "idle surge" that others complain about before I try to troubleshoot.
Thanks!
Ya, that sounds like Idle surge. Generally, your car will run about 1500 RPM's for the first few minutes that you start it cold until it warms up. It's generally a good idea to let it warm up. However, once it's up to temp, it should sit at about 800 rpm's, give or take a few, and not surge. If it is, you might want to check your car for vacuum leaks/boost leaks, etc. Just do a search on Idle Surge and you'll find lots of good info.
Usually the good thing to do is block the EGR, block the FIAV, replace the ISC, and make sure the biss is all the way down, sometimes they become rotten and you must replace them. Read up on those things, and that should help significantly.
James :laser::talon:
Thanks all....
I read the same thing about the lower honeycomb to.
Interestingly enough, the previous owner provided me with an extra maf that seemingly looks brand new.
Has it's lower honeycomb intact etc.
It seems that removing the lower honeycomb causes scenarios from no problem at all, to plenty of problems.
Funny thing is that I can't do a damn thing with my SAFC to stop the idle from bouncing. Makes me lean towards a bad ISC.
Im not sure, but i drove mine around for quite some time with the lower honeycomb gone, and it ran fine. No improvement in gas mileage. When i went to the maf-t, my idle surge went away. Then, i had to get a new ecu, and it came back. WTF
I also removed my lower honeycomb, but it didn't idle surge, the only thing i noticed different, was that if i was at 4 to 7 grand on the tach, and shift into neutral, or clutch it, it would sometimes die or get to extremely low RPM 200 to 400, but i got a 2g mas now so it's all good now:rocks:
Thanks for all of these responses.
This car also "supposedly" has aftermarket cams. Vacuum on my autometer is only between 15-17 at idle and it seems like alot of the dsm's get 20 at idle.
I wonder if cams could be causing this...LOL.
