Is this good????
GORBS88
549
3
May 26, 2004
Oliver, BC, Canada
I have ran my car with the g-tech since i got it and so far this is my fastest time....I am wondering if this time is good for my mods....92 Awd..
13.7@101
0-60 5.1 sec
Mods
3INch turbo back
180 stat
hacked air can with K&N
MBC@17
Re-wired walbro 190
Any thoughts welcome... :thumb:
Hmm. Which Gtech is this? is this the first version with the red lcd number display? or the new bad ass one that goes for like $350+?
Either way, I would take it as a ballpark figure. Nothing concrete per say.
A bump in the road can throw the gtech off considerably. Mamemba dat.
Take it to the track and find out what its REALLY hitting.
Dont give me the old "But its too faaaarrrrrr", junk.
Good luck
IF you find a really flat road and use the same stretch over and over it can be a great tool for comparison to itself. I happened to find a great local road and on my first version gtech pro my ET's are the same as they are at the track, the MPH on the gtech however is considerably higher.
As far as your times I think they should be a tad lower for the mods. My car was faster with a stock down pipe, pump/wire, and 16psi. Maybe work on the launches?
thanx for all the input.....sounds good.....i think the g-tech should be reasonable but not perfect...i do run on the same level road everytime.....i know if you use a different road then the numbers will change.......and for the track....i am not using the too far away attitude it is just that i work lots and dont have time to drive 6 hrs to the track...i am not lucky like some and drive 10 mins to track....i thought that time was fast for the mods but i am new to the dsms.....i have seen guys with more mods still stuck in the 14's...hehe..all my goal is low 13's......can i do that on stock injectors???...that is my only problem i am not to sure when they will be maxed.......
They'll be maxed when your logger says their maxed, but low 13s should deffinatly be reachable, and beyond hopefully.
