Is this bad or good for my engine build?
captain_kurt
44
Jul 2, 2013
Boynton Beach, Florida
So I have been going through the process of doing an engine build process. And while I was honing the first cylinder and cleaning it, I found a slightly rough ring inside the cylinder walls.it has a discolored ring in the pictures. Will this affect my compression or does this require me to overbore the cylinder? Is it possible that I will be fine with just honing it?
Depends on how long you want the new rings to last.
You may be able to pop some new rings in there and get a few miles before that rough patch grinds the compression rings.
Looks like water sat on top of the piston and the rings rusted to the cylinder bore.
Personally, I would bore the block and start with a round straight bore.
Yea I was thinking of over boring it just to be on the safe side. What size overbore would be good? I called the machine shop and they said that they need the rods and pistons to over bore it. Is this true or can I tell them to overbore it a certain size?
You want to bore the cylinder as little as possible while still removing the damage. They do need the pistons in order to set the piston-to-wall clearance when honing, but I don't see how they can expect you to buy pistons when they don't even know what size they're going to need to bore the holes. What if you buy a set of 85.5mm Manley pistons and the block has already been bored once and needs to go 86mm? Then your $500 pistons are really nice paperweights. And they don't need the rods to bore the cylinders, thats just nonsense.
In short, find another shop.
  • Wanted 6 bolt NT water pipe
    • chrisman287
