IS this an evo 3 turbo
You will need a picture of the compressor wheel. The compressor housing on the 14b/16g are identical on the outside, With the same TD05H numbers also. I'll attach a picture of my 14b's and a 16g to show you. The 14b is the one of the left, The 16g is in the middle, And a 14b on the right. The single turbo picture is also a 16g.
The turbine housing up at the top, On an evo 16g is alittle different. It's not an exact square. To make sure it's an evo 16g, You would hafto take the comrpessor housing off and measure the wheel. Hope that helps.
Edit: I just found a picture in the classifieds of an evo turbine housing, You can see how it is shaped alittle bit different from the turbine housing that I posted of one of my 16g's I have.
here r some picthe first one kinda hard to see, their is some oil in their, thats normal right?better be its abrand new turbo, and here is the pic of the wheel it better be an evo
