Is this a TD05h or TD06h 20g?
Switzerland! if the housing is a larger diameter than the regular 14b housing then it is likely the TDO6H
This is the TD06-20g, I have one on my car too:
Doesn't ANYONE realize that TD05H/06/06H means both turbine wheel and compressor housing???? The pic shows a TD06 compressor housing, but the common reference to 05H/06/06H is usually the turbine wheel. You can't tell from those pics what wheel it has. Take the turbine housing off and measure the wheel.
http://www.turbochargers.com/Turbos/TurboUpgrades/SeeTheDiff.htm
Scroll down for turbine wheel sizes.
Yes, it's an 06 compressor housing, as every 20g should be unless it's a "sleeper". Unfortunately, the real question is whether the turbine wheel is an 05H, 06, or 06H. You can only tell that by pulling the turbine housing off and measuring the wheel.
