Is this a 91-94 oil filter housing?
Hiitman
482
4
May 12, 2004
Colorado Spring, Colorado
I have a feeling that RRE used a 91-94 oil filter housing when they put a 6bolt in my 2g. I just wanted to make sure that is what that is. Can I use any of those ports for an oil cooler or should I just get a 90 ofh?
Ok thanks. So I can't use any of these plugged ports to run an oil cooler? And by provisions do you mean all the lines and fittings?
I know what a 90 ofh looks like. What I was wondering was if it was at all possible to use an oil cooler on my 91-94 ofh.
Some people take those big ass allen screws out to make a cooler, but the problem is, one is filtered the other is not. Basically if you were to make a cooler out of it, you would bypass the filter 100% of the time.
Not only that, but you would also always be cooling the oil. That would suck especially in extremely cold weather.
