is there a way to tell if its a 6 or 7 bolt from the outside?
DSM-Franek
240
Sep 16, 2006
Elmwood Park, New Jersey
is there a way to tell if its a 6 or 7 bolt from the outside of the engine? besides the VIN?
thank you!
yessir externally looking at the engine.. is there a sensor in a different spot anything like that?
Strm Trpr said:
You can look at the driver's side door jamb and look for it's manufacturer date.
If it's before 4/92, then you're golden with a 6-bolt...
its a 2G but thank you sir :rocks:
thank you!
Based on your OP, it appeared that you were looking at a 92 1g.
Maybe if you worded your OP better, we'd all get what you were asking.
I did notice you had a 97 GSX, but how the hell could you tell if your motor in your 2g had a 6-bolt by the VIN...
delta448 said:
Just curious, where is the VIN on the engine located? I have a swap, (performed by previous owner) but would just like to know a little more about the donor vehicle.
Looking at the passenger/flywheel side of the block, it is located at the upper left corner, just below the head. Very small letters and numbers and very hard to see. You may have to spray some type of grease cleaner on the area to see it.
Mike
Mike
:thumb:
