Is the Power Transistor/Ignition Module located in the Coil Pack?
fourgsixthree33
1,244
46
Oct 25, 2010
Athens, Pennsylvania
I am buying a 92 Laser RS-T tomorrow morning that needs a power transistor/ignition module. Is this located in the coil pack? The laser will no start as it does not have spark and a shop told the owners that it needed a new ignition module. I am under the impression it is inside the coil pack.
Good let us know what happens, glad to help good luck.
Will do. I hope it is an easy fix and it is either the CAS or power transistor. The car is like an hour and 45 mins away. I don't have a spare ECU so hopefully the ECU is fine.
Hey I know im late, but the CAS is the CAMSHAFT ANGLE SENSOR. I do not believe the 4g motor has a crank sensor. But the CAS is on the left side of the motor, roundish object coming off the intake cam. This will cause the car not to start as well. Also check the MPI fuse (located on positive terminal) and theres another fuse behind the stereo that i forget the name of. Its gold though. GOOD LUCK!
IM HAVING THE SAME PROBLEM SO LET ME KNOW LOL :)
Is it just me or does that power transistor look like the connector is cracked and broken?........:confused:
That could definietly cause a no start....may want to replace that first....
Might be. But it wasn't my problem since that pic was one I found on google haha. I ended up not buying this Laser so I have no idea what the problem may have been. Decided not to buy it since it wasn't AWD and....I need AWD LOL.
