Is the drop in boost true about the 34 mm flapper mod?
adam355
315
Aug 26, 2003
Urban, Wisconsin
I have a BIG 16g and have everything ported and it still creeps badly. I wanna get the flapper mod done, but I heard the boost drops a couple pounds on some people when the door opens. Is this true? Does anyone know from experience?
The reason you get the 34mm flapper mod done is to flow more out of the wg passage. If you get this done, all you would probly have to do is adjust your boost controller again (MBC or EBC).
Its not a matter of losing boost, its helping expell the exhaust gases better through the wg passage, hence controlling the boost. Then just go from there.
THE DROP IS TRUE.
When you install a larger flapper door, you present the exhaust gasses with a larger area on which to exert force; as such, exhaust pressure will blow the door open, and you won't be able to hold boost at higher rpm's.
I know lots of people who couldn't hold more than 18-19 psi at redline.
Originally posted by kpt4321
THE DROP IS TRUE.
See! This is what I'm talking about, but I need replys from people who actual have big 16gs with the mod done! Thanks
Why dont you try to search instead of telling everyone that they have not answered your question. There are tons of threads about 34mm flapper mods.
