Is it recommended to buy new gaskets when taking out throttle body for cleaning?
It is not a year thing, it is all dependant on the wear on the part. I have seen 99's with more WEAR-AND-TEAR than my 97.
Check them over.
Check them over.
Ok, its just that I wanna have them on had if I need them and I don't wanna order them if I don't. They're prolly cheap though, I might as well...
They're like $3-4 from the dealership :thumb:
Yes, most gaskets are reusable. Just throwing out the general rule. Check everything over. Some gaskets are pointless to replace, even for $4. Not that I am cheap, it is just the rule of, "If it ain't broke, don't fix it." That I usaully go by.
If you are unsure what a bad or good gasket looks or becomes when removed then just replace them. I can give you 3 cases of reuse or not. Each has correct answer. It is up to your knowledge to determine.
TB gasket
Valve Cover Gasket
Spark Plug Well Gaskets
Head Gasket
Which one needs to be replaced REGARDLESS?
That is what these boards are for. Helping out others so they inturn can spread the common knowledge it holds. :thumb:
Sorry, stealing the thread for a quick question. When do you use silicon seal? I'm almost done with fmic install, do I need to silicon the TB, Turbo outlet and BOV gaskets?
Thanks. :talon:
I used rtv on my bov and tb gasket because they were leaking. You can just for peace of mind. What turbo outlet are you referring to :confused:
16g to J pipe
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
