Is a 1g smic better then my 2g smic?
VegasTSI
101
Oct 29, 2005
Las Vegas, Nevada
I just picked up greddy smic pipes, and I am planning on doing turbo upgrade in very near future. I dont have the cash for a fmic and new turbo , so would it be worth it to pick up a 1g smic to replace my 2g stock smic untill I have cash to go with a fmic?
I will be getting a 14b turbo seeing my t25 is done, then i will upgrade to a b16g within the next few months
pick up a 1g side mount. cut the the outlets off and have your 2g outlets welded on. if you just use the 1g stock you wont see much difference. but the 1g core is slightly bigger and flows better, but has very small diameter outlets. using the 2g outlets fixes this. hope this helps you out
you should look into getting a supra smic.. i believe its make 4 supra's that have the good one...
  • Wanted 6 bolt NT water pipe
    • chrisman287
