IPT's Core charge refund??
OneFastEclipse
255
Jun 20, 2002
Canton, Ohio
Hi, I recently bought a valve body from IPT and shipped back the core like 2 1/2 weeks ago. I still have yet to get the refund. I emailed John like 2 or 3 times about it and even called the shop have had no luck. Any of you had any problems with them in the past? I'm sure they're prob just busy but thought I would check. Thanks
Have you installed it? How do you like it? I'm ready to get one and wanted to get some input.
The install was very easy. You didn't have to take the tranny out. Just drop the oil pan and everything was right there. As long as you have some knowledge about trannys, you'll be fine. I recommend you read the write up on installing the shift kit. Even though you won't be actually installing the shift kit, it shows the removal process of the valve body. Shows which bolts need to come out to drop it, etc. I can swap the valve body in about 1 hours time. (Had to do one in a parking lot) Haha I won't go there though. Need help or have questions, give me a buzz.
