Intermittent misfire on 1&4
awdtalon4451
521
Aug 23, 2007
Ocean springs, Mississippi
Dealing with an on going issue. Car has a slight misfire on #1 & #4. Its not a hard miss so I've pulled the coil pack off. Measured resistances on primary of 1.2 ohms and secondary was 12.3 on a 200k scale. Not a 100% on the secondary but I'm pretty sure its shot.
My question is could the misfire on 1&4 be cause by something else along with the bad coil?
Changed the coil pack and it runs much better. Cruising and under throttle have improved dramatically. It still has a sputter at idle though. I guess ill be testing TPS and ISC soon.
